About to order some case accesories...
Fel
And i wanted to clear it with the experts first...
Here's my case..
(http://www.newegg.com/Product/Product.aspx?Item=N82E16811146041
I'm going to order these two, put the non-led back 120mm in the front, and replace it with the bgears..
http://www.xoxide.com/bgears-120mm-bluechrome-fan.html
Are these things actually worth it? Not but like $6 bucks shipped.. cheaper than cathode tubes, anyway.
http://store.yahoo.com/xoxide/red-uv-reactive-slot-cooler.html
Then i need to buy a carrying case since my case scratches so damned easily... Will it fit? I don't know if it is adjustable or if it only has those 4 configurations(mid 1,2 full 1,2).
Thanks a bunch.
My experiance with those slot coolers is that they're pretty loud. You might undervolt it though.
The bgear fan is a quiet fan, but it spins at a very low rpm. Sometimes it won't even start up, and you have to use your finger to give it a nudge in order to get it going.
