About to order a new system - Feedback?
Before I pull the trigger on this, look for some feedback. Thanks
Mobo: MSI P55-GD65 ATX LGA1156 P55 DDR3
Proc: Intel Core i5 750 Quad Core Processor Lynnfield LGA1156 2.66GHZ 8MB Cache Retail Box
Memory: G.SKILL F3-16000CL9D-4GBRH Ripjaws PC3-16000 4GB 2X2GB DDR3-2000 CL9-9-9-27 Core I5 Memory Kit
Videocard: Gigabyte Radeon HD 4890OC 1GB 900MHZ 3.9GHZ GDDR5 PCI-E Dual Link DVI-I/HDMI CrossFireX Video Card
Case: Antec Three Hundred
PS: Antec Earthwatts 650W Power Supply ATX12V V2.2 EPS12V Active PFC 80PLUS 120MM Fan
DVD: Samsung SH-S222A/BEBE 22X Dual Layer DVD Writer Black IDE OEM
HD: Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive Oem
Wondering if I should hold off on a videocard for now, I can tough it out on my current 8800GT until 58xx later if one can be had for about $250. Have not read too much into them yet.
Im not sure how hot the new i5s run but the Antec Three Hundred does not come with front fans (to promote airflow) Just something to think about. By the time you purchase extra fans you can buy some around the 80-90 price range.
That looks good, but i would hold out on the video card untill the new ones are released, Oct 11, I believe. Get the new VC then.
No hard drive?
No hard drive?
+1. Even if you're not getting the latest card, prices should be driven down.
No hard drive?
Heh edited the original post but it was
You might want to buy coolermaster 590 case and corsair hx 620 instead. Waiting for 58 is a good idea. The rest is ok.
Yate Loon 120mm fans from jab-tech.com are under $5 each. ;)
