About to make a big order, please help (quick responses would be nice)
mattjbak
Ok, so I've finally decided to watercool. I just have to much free cash right now and nothing to do with it so here goes....
I am planning on these items based upon reviews. They are from sharka and petra online sites. Please give your input and following the list I'll have a couple of questions...
First off the hardware to be cooled:
Opteron 165 @ 2.7 Ghz
x1900xt @ stock for now
Both in a Lian Li v1200b plus
The list of "to buy" at this point:
AquaXtreme MP-1 Universal GPU Water Block
Swiftech Storm Rev. 2 Extreme Performance Universal Waterblock - 1/2"
Laing D5/Danger Den D5 Inline 12vDC Pump
Swiftech MCR-220 "Quiet Power" Series Radiator - Black
Petra'sTech "Gel-Stuff" Vibration Absorption Block
I am new to this stuff and would love some input.
1) I want to go with 1/2" tubing.... can someone link me to the exact Tygon tubing that I would need, and also how much should I buy for safety in constructing the loop?
2) As far as the liquid goes... can someone recommend a good mixture and maybe link to items included?
3) I love the look of Aquacomputer stuff... but I can't justify paying the ~$100 for the Cuplex XT with fittings. Am I smart to make this choice? Is AC overpriced for the looks or will it really be better than that storm?
4) I also need a recommendation for a res. I like the aquatube, but once again, it is pretty pricy. I want something that won't cheapen the look of my v1200b plus.
5) Please recommend me some good performance/noise balanced fans to use with that radiator.
You want Masterkleer 7/16 tubing, available at petra's ( i think) or mcmaster-carr. It's about 39 cents a foot, is super clear, really flexable. And really cheap. It's the best.
Distilled water + a splash of antifreeze + uv dye.
For sheer performance, that setup will outperform. AC is more of a low-flow system that's quieter. It's up to you, really. Are looks that important?
So you're saying that what I have would work better? Looks honestly aren't super important because I don't care to add a case window.
Also, this may be a stupid question, but what is the OD and ID?
Mine has had a slow leak ever since purchasing it right at the threads. I hate the thing now.
1) MP-05 SP LE CPU Waterblock
2) MP-1 GPU Water Block
3) Alphacool Laing DDC-Pump 12V Ultra, AquaXtreme 50Z-DC12 Mag Drive Inline 12V Pump or Laing D5 pump
4) PA120.3 rad with (3) Yate Loons or BIPro III rad with (3) Yate Loons
5) 1/2" Tygon R3603 or 7/16" Tygon R-3603 tubing
6) Plastic tube clamps (18) need some spares.
7) 1/2 plastic Tee for "T-line"
8) 1/2 Delrin fill-port
9) Ramsinks for vid ram
10) Your favorite beverage to celebrate your new system! :D
Mixture: 95% Distilled water, 4.8% VW (Pentosine-blue) antifreeze, 1 cap Water Wetter, 4-5 drops non-alcohol iodine. JMO
mattjbak said:
Thanks....
Anyone know the performance difference b/t Rev. 1 and 2 of the Storm block? Is it worth paying more for rev. 2?
Go with this...MP-05 SP LE CPU Waterblock or I can sell you my Storm rev2 so I can buy the MP-05 SP LE CPU Waterblock. :D
Do you have proof to back that up? Also do 2x120 Rad's support 2 on each side or just 2?
Order has been placed for everything! Let me know what you think!
Here is the list:
Radiator Swiftech MCR-220 "Quiet Power" Series Radiator - Black $39.99 - Petra
CPU Block AquaXtreme MP-05 SP Limited Edition Universal $76.00 - Petra
GPU Block Swiftech MCW60 GPU block $30.00 - FS/FT
Pump MCP655 pump (Laing branded) $60.00 - FS/FT
Tubing 7/16" ID (5/8" OD) Masterkleer $2.45 - Petra
Reservoir Aquatube and Faceplate $62.83 - FS/FT and Sharka
Fans YATE LOON 120mm Case Fan - D12SL-12 (Quan: 2) $7.98 - Jab-Tech
HD 5.25 Scythe Anti-Vibration HDD Stabilizer 2 for 3.5" HDD (Quan: 2) $13.90 Jab-Tech
Pump Block Petra'sTech "Gel-Stuff" Vibration Absorption Block $3.99 - Petra
Petra T/S Tax and Shipping $17.85
Jab-Tech T/S Tax and Shipping $7.58
Total $322.57
You do realize that the Aquatube does not have fittings available large enough for your setup right?
that can be changed can't it? I mean sharka sells them with all different fittings...
That's alotta $cratch! Don't know about the Aquatube thing, but I'm glad to see you went with the 7/16 ID tubing. When I re-did my system I opted to go with 7/16 and couldn't be happier. Flexibility and routing is much better than compared to the 1/2" stuff.
Want an easy fix? Pull the fittings out, put a coat of silicone on the fitting's threads then screw them in and let it cure. No more leaks.
Thanks. I'll probably do that, or suggest whoever i sell this thing to for $5 to do that. It's just such a pain to breakdown a watercooling system. For right now I'll just top off weekly. I'm intent on getting a PA120.2 now
@ scwam, you need to clean out your message space, I tried to reply but it says that your box is full.
email me: sigfever@comcast.net
Throwing good money after bad...such a waste. You won't notice any difference to the good and all because you had either a loose or cross-threaded barb.
