You need both and your not going to see a significant benefit if you are just plugged into a router.
Teaming will really shine if you are doing file serving with the box and have a raid to push and plenty of users to hit your device.
Teaming will really shine if you have two high speed Internet connections and you really want to shotgun those downloads.
Teaming into a switch or hub for a normal home office without pushing media or something of that sort across the switch.. and again your throttle point will be the listening devices.
So first... yes to use teaming you need to enable both ports.
Second. What are you doing where you think teaming will be an asset to your configuration?
In your shoes the best bet is. Just disable teaming and don't worry about it again.
Tell me what your Internet connection is. Based on what you just said you have a connection in each room? Or do you mean that you are using DSL? And it is off of your phone jack?
I have a coworker who does the teaming though admittedly he does his teaming via a router I believe but here is the premise.
He subscribes to a Cable modem service for 40 dollars a month as well as a high speed dsl service for say 54 dollars a month.
His downstream on his cable modem is 8mb (Megabit not Megabyte.)
His upstream on the cable mode is 256kb.
Downstream on the DSL is 6mb
Upstream on the dsl is 512kb
Via teaming his downstream theoretical limit is the sum total.. or 14mb down and his upstream is 768kb up.
That is just an example. But that is what teaming is for. Or for server environments. IE the controller can do it.. so they give you the option. In 95% of home installs it won't do any good. But for those of us that have this mobo on a file server hosting a raid five array of 12 terabytes of High definition videos (Pron) teaming allows us to stream content to multiple rooms in the home simultaneously and makes that raid 5 array's bandwidth more worth while.
I really hope that helps and doesn't collude things too much for you.
I have a cable internet it is called Optimum Online Boost of a 30Mbps down and 5Mbps up I pay $30 for that every months. I asked for another one and asked them if it can be put in my room together with the cable modem I have now they say no it must be installed in another room separatelyso I cancel it
Purchase the service for your "neighbor", but put the second modem in the same room.
I will try that but who is gonna install [such as cut the cable wire and put them together and hook it up in my room with the other modem] ? I have nobody with that skills to do it...
You know what that is my bad... damnit what is the process called when you use two connections and effectively get more bandwidth from it... Aggghhh...
I'll have to ask Jason at work because I can not remember what it was called to do that.
My apologies for the wrong freaking definition.
Hummm... load balancing is the premis... but is that the term... I remember doing this back in the day for my modems to duel channel my stream into the internet before cable modems or dsl... I want to say it had some hip term then.
Anyway yes the real term is load balancing. My apologies for confusing the op.Either way turn it off. lol.
Shotgun technology is what I was thinking of with modems... sounds like everyone has a term...
I think load balancing may not be it because if you have one pipe larger than the other you get a loss of beniift... like having a 200 and an 300 gig drive in a raid 0... you will only get 400 gig of space.
What are you guys talking about? Teaming is not load balancing....
Teaming is technically using two NICs, one for receive and one for transmit. This is great on servers and large switches where the bottleneck is the NIC connection, but it has no use for combining two internet connections.
Woot thanks for the update phil... .
do YOU know what you're talking about? NIC teaming is precisely that, creating one logical connection that two or more physical connections use to share the "load". You explanation of teaming is horribly incorrect as well, I suggest that you do a quick read on the aggregation algorithms before speaking anymore.![]()
Bonding ? Diamond and BOCA used to call it shotgun technology
