malice8691
- Jan 8, 2004
I just upgraded my mb to an abit AI7, which I am very pleased with. I bought 2 new sticks of ram to go with it as well. I bought 2 MUSHKIN cas 2 rated (2-3-3) pc3500 (433mhz) sticks. I have been running at the default voltage the mb selected which is 2.6v. I started running tests using memtest and found that I could only run stable at 429 mhz if I bumped the voltage up to 2.7v. I know I'm not hitting the limit of the cpu because I know its stable into the mid 140 mhz fsb range at stock voltage and im only running at 129 mhz fsb. I had assumed that the specs that were stated for ram were at stock voltage. Is it normal to have to bump the voltage up for the ram to perform as advertised? I don't mind running at 2.7. I think im within the safe operating range but i just thought it would perform as advertised at stock voltage.
