?? about neo2 plat
MAngelo
939 neo2 plat
a64 3200 stable at 10x240, mem@1:1, 2.5,3,3,11
Last night, feeling the need to tweak, I wanted to see if I could get 8x300 running stable. I did. BUT,,, I had to lower the ram divider to 100 (1:2) to get to windows. A 133 divider would give me 200 mhz on the ram, but even loosening hte timings to 3-4-4 didnt help. (the ram has no issues running 3-4-4) . 8x300 with the ram at 150, is prime stable - for a couple hours. Tried to give the Hyperx more voltage (pc3200AK-ch-5), but it just gives more errors in memtest above 2.7v. Vcore on cpu is 1.525, wont go much higher without diff bios.
Any thoughts on how to get the divider up to 133, for a ram speed of 200 mhz with the cpu at 8x300??
thanks in advance
The divider will tighten internal memory timings. I use a modified bios, but the link is down now. You can do it with A64 tweaker though. If I remember right, you change these settings. They won't affect performance much at all.
TRC-13
TRFC-19
Read Write Que Bypass- 16x
Bypass Max- 7x
Dynamic Idle Cycle counter- disable
idle cycle limit- 256 clks
And you can get voltage up to 1.62v atleast on most bioses for it. I am using 1.45 with 8.3% overvolt.
I tried the a64 settings- no go. I can only boot at 300x8 if I set mem to 100mhz divider- giving 150mhz ram speed.
Is there a gain or loss to had running 300x8, with mem at 150mhz, as opposed to 240x10, mem at 240 ??
266x9 works for me with 166 ram divider putting ram at ~220.
300x8 no go with ram at any divider above 100- even bumped cpu vcore to 1.58- no help.
I feel its the mem controller on the cpu, as 300x7 works with the mem at a 133 divider, giving a 200mhz ram speed.
Oh well, back to 240x10 :)
