? about HDTV viewing and HDCP keys
badboysean
I was looking for a little insight into watching tv or HDTV on my computer.
My monitor is a E207WF 20" widescreen with a HDCP-compliant DVI input and my graphics card is a HDCP supported 8600 gt.
Now is it just a matter of hooking up a cable from my cable box to the video card kind of thing, or is there an online option that I can use?
Also, is the main purpose of using an HDCP monitor and graphics card the ability to view movies through an HD-DVD and or Blueray player?
Could you even play those without a HDCP compliant card?
What exactly are the main selling points of having and HDCP compliant monitor and card?
Thanks in advance.
After reading a few articles, I was wondering if the 8600gt is actually capable of outputing a stream at 1920x1080 or if there are still issues with these cards being listed as HDCP when they dont even have HDCP decoding keys.
You need a HDCP display + HDCP source to support content that requires an HDCP protected path.
HDCP is only on DVI + HDMI right now. not vga/component/etc.
Right now this is mainly blu-ray + hd-dvd. If you had a blu-ray drive, or hd-dvd drive in your pc, and the appropriate playback software you could watch high def movies.
If you had a standalone blu-ray/hd-dvd player you would be able to plug them into your monitor with the right cable, not into your computer.
If your cable box has hdmi/dvi you could plug that into your monitor, not your pc. You could plug svideo/composite into a video capture board to watch on your pc, but that wouldnt get you HD.
The main selling points of HDCP is that its needed* for blu-ray/hd-dvd over a dvi/hdmi connection. You would be prevented from playback without a compliant video path.
*of course theres things like the image constraint token which may modify this restriction.
It doesnt sound like you have any need for it right now. Its just nice to have. I wish my monitor had hdcp support, as i'd like to get a hd-dvd drive + software.
Thanks ambientZ, thats exactly what I was wondering. I dont really plan on buying an HD-DVD or BR player just to watch movies on my monitor so thats good to know.
What about the HDCP support on the video card though, whats this all about? Are you familiar with the 8600GT and its capabilities as a TV tuner (if there are any)?
If you want to watch HDTV on your computer, you can just get an HD tuner and throw it in your pc and call it a day. You don't need HDCP on your computer unless you have CableCard or HDDVD/Blu-ray.
Now there are different types of HD tuners for your PC, so make sure you choose the right one. It all depends on what your sources for HD material are. (over the air, cable, satellite, etc) Also make sure your PC is fast enough to handle it. HD video is a little more demanding than standard def stuff.
Thanks for your response w1retap. I know that alot of the AIW cards had a type of tivo feature built into them, I wonder if my 8600gt can be used the same way I will have to look into that.
hd tuners are mostly useful for over the air (OTA aka broadcast) hdtv. Digital cable uses QAM which hd tuners arent as compatible with (some are). But the further complication is most if not all channels would be encrypted. HD tuner cards, if they can do QAM, can only access the unencrypted channels. For encrypted, you need a cable card. HD tuners dont generally need HTCP to connect to a display.
Currently you have to buy a full pc with cable card included to get it.
Well for the time being I suppose I will just stick to watching HD on my main plasma in the living room.
All the talk about HDCP compatibility with my new monitor and video card got me wondering what the big deal was but seeing as how I dont plan on buying an HD-DVD or BR player for my comp anytime soon then I guess it doesnt mean a whole lot.
Thanks again for the help guys.
