About cpu fans
vietkangta
when im putting a fan on my heatsink its suppose to blow towards cpu right, and not away towards the side panel?
And when i have case fans, its suppose to blow outside the case and not into the case right?
Also is there a way to lwoer your cpu fan speed, mines running at 4.6k and i want to lower it to make it a bit quieter.
In reference to the CPU fan, correct. It should blow onto the heatsink. As to the case fans, it depends on the location. Generally, rear and top fans will be exhaust, and front and side fans are intake.
Get a fan speed controller. You can either get a bay mounted multi controller like these or you can get a single controller like this. You may also find a single controller that mounts in an empty PCI slot.
