about $115 to spend, which card?
paco
I figure I can get a 5700ultra or a 9600pro for about $115 (used most likely). The most I can probably go up is to $125. What are your suggestions for this range? I play stuff like UT2K4, Call of Duty, Battlefield games, etc. Currently I have a craptacualr MX440.
I would suggest holding off til ya can come up with alittle more cash, the prices on the 9800 pro's are dropping. Got mine a couple months back for under 200 new. You would get alot more bang for the buck that way.
the 9600 pro is one you can get for 125 in a retail box, brand new at newegg. I would by the 5700. that card is lackluster. the radeon 9600pro is even better then the 5700ultra in a lot of cases.
It also sorta depends on what kind of system you have. If you have a crappy PIII 750MHz system with 128MB RAM and such, you won't see much improvement with anything over a GeForce4 Ti4200 or something similar. However, if you have a kick-ass system, I'd personally sell a bunch of plasma over several months and save up for an ATI Radeon X800 XT PE or nVidia's GeForce 6800 Ultra...but that's just my opinion.
i would say if u wanna spend a little more to get a 9600xt. or wait for a 9800 pro
I have a crappy MX440 also. I'm just gonna save up the extra $50-75 for the 9800 Pro 128MB, instead of getting a 9600 and then realizing I should've saved a little extra. All the reports I've read say it is DEFINITELY worth it. It will handle those games with no problem. I'm interested in it because of HL2. I'm an avid CS player, and I can't wait for HL2 and CS /w HL2 graphics engine.
I'll have to take a closer look at the 9800's. When are the prices supposed to drop on those? If I could pick up one of those with only a little more cash, I might do that. But right now anything would be better than my MX440. I can't stand it anymore. I would have gone right for the 9800 but I had to buy a new PSU.
I'd say save up a little more for a 9800np, it is really cheap and can be flashed to a pro.
Is there any brand of 9800 I should stay away from? ATI, Sapphire, Gecube? Just want to make sure I get the best for what I am spending.
$125 now... hmmm, I would wait a little bit longer as the 9800 Pro in a lot of people's boxes are going to be going up for sale as they buy the X800's.
Even brand new ones are down to $200 or so. I would think you should be able to find a 9800 Pro very soon for just a little bit above your current budget.
If you absolutely must buy now, maybe get a cheaper card to hold you over.... like a used (or refurbished) GF4ti4x00 for around $60-70 and put the other $50-60 towards your savings for a 6800 or x800 down the road when they are cheaper and you have saved more.
not_the_pope said:
I found a refurb 9600xt for 125 on newegg. Great card and the price was right.
How is the 9600xt compared to a 9500pro? I'm also thinking about a refurb ATI 9800pro for $170 at NewEgg, I'm just not sure I can go that high right now.
Look around, there are 9700pros for under $130. In the f/s section and newegg refurbs. I bought a BBA 9700pro for $100 from the f/s section for my friend.
Undoubtedly the most bang for the buck you can get.
I just got a brand new BBA 9700 pro with 1 year warranty for $140. As far as I'm concerned, you just can't beat that.
another vote for the 9700 pro. Mines wrecking the vast majority of 9800 pro's and xt's. absolutley demolishes the 9600 series. I hit 22k in 3dmark 01 with mine. Plays far cry @ 1280x1024 every setting maxed smooth as buttah no aa/af.
I just sold my BBA 9700 Pro for $110+ship
If you look around you should be able to find near as good of a deal I gave.
Check the deals section in the Rage3d.com forum. Post a want ad for a 9700pro or 9800 NP and how much your willing to pay and you might get some good responses.
Right now www.rage3d.com is down for a bit as they are in the middle of upgrading to VB3.
I've got a couple of 9600pro, 9600xt, and 9700pro's on my watch list on Ebay. If I could get a 9700pro for about $100 that would be awesome. I always keep my eye on the deals forum.
Thanks for all the suggestions!
Be careful when shopping for a 9800pro as some companies are selling them with 128bit memory instead of 256bit. I'm not talking about ram, but the bit, the speed, so if you by a 128mb 9800pro, make sure it's 256bit. 128bit is like getting a 9500-9600 card or a 9800 SE in a way.
You might also wanna keep your eyes open for a 9500pro, performs just as well as the 9600xt, and you might be able to pick one up for pretty cheap
