Abit VIA KT333 mobo
MiamiBigAL
I bought an AMD barton 3200+ 400mhz fsb cpu for my Abit VIA KT333 mobo without realizing that the mobo apparently only supports up to a 266mhz fsb. Yeah, really stupid, don't rub it in cause someone told me it would support it ;-(. Right now I am running the processor at 150mhz FSB (i.e. 300 with double data rate) which is over the apparent limit but it is running fine, at least for now. I was wondering if this is safe to do? My CPU temp is like 38 idle and probably not too high under load, but I am a bit worried about the mobo.
My second question is concerning what mobo to get in the meantime. My comp specs at the moment are:
3200+ 400mhz Barton AMD Athlon
1GB PC3200 400mhz corsair "value-ram"
ATI Radeon 9800 Pro 8x AGP
couple standard ATA hard drives, 40gb and 60gb, 7200rpm
480 Watt "demon" power supply.
And I currently need 5 PCI slots for the other random stuff
I'm looking into getting a mobo that will support all of this but I'm not that interested in upgrading in the future as I think 64-bit processors are going to make these obsolete in a year. I'm still welcome to any other opinions anyhow.
So, I'm basically interested in a mobo on the cheaper, non-upgradable side but will still run everything above very efficiently. Please recommend.
I would greatly appreciate any feedback.
Thanks,
Alex
