Upped the voltage to 2.7 volts on the suggestion of "RAM Guy" in the Corsair forums, switched to 2-3-6-3 timing at DDR400. Turns out most people have problems with the RAM because you really have to be careful putting the DIMMs into the slots (otherwise they won't fully connect) and also DIMM slot #2 seems to be the better choice when you have only one memory module.
