ABIT VA6 Screw up
silentnight3985
One of my friends came over today to help put my new server back in one piece:D i went to the radio shack to get a thermister for the cpu temp lead and when i came back he was looking pretty pale in the face,i asked what happend and he told me he tried to remove the thermister built in the mobo for the case temp and cut 2 small wires in the mobo right under the thermister,well needless to say i dont have the vid card here for it and all my other vid cards are to much for the old simple 2x agp(we tried a few b4 this and they dident work) so now im stuck not knowing for sure if my mobo is shot,ill have the vid card for it tomorrow or the next day.the 2 wires go to the chipset so im praying they were for something that im not gona be using,i fired it up with out the vid card and it booted up like always no beeps and no smoke,does any one know where i can get a kit to repair the 2 wires if they are bad? or will ABIT reman it for me for a price?
Don't you have a PCI card?
I dunno if it's working or not. It should beep if it's hooked up to a speaker and doesn't have video. You don't have a PCI or ISA card?
I'm still trying to figure out what possesed your bud to remove the CPU thermister in the first place. If he crushed something in the CPU area, and the board as old as it is, I dunno if Abit'll fix it or replace it.
post a decent pic of it. This will help others in the forum help you.
is the cut large or small? deep?
depending on the severity of the cut, it is entirely possible to fix it in about 10 minutes or less with some soldering skills.
if it's a shallow, clean cut, you can simply scrape off the coating on the traces on both sides of the cut and bridge the gap with a bit of solder or use a thin wire...just don't cross the connections.
It wasent the cpu thermister it was the onboard thermister for the case temp,and i still have no idea why he removed it.I do not have a cam good enuff to take the pic,as far as the cut goes it was clean but it took out a .5mm section of one wire,it would be a bitch to fix it unless i jumped from the start of the wire to where ever it went to.No i do not have any pci or isa vid cards yet i was told my card for it would be in tomorrow,thanks so far keep the post comming in.
not sure if you knew what I meant, so I took a pic on an old motherboard (Abit IT5-H actually...too bad it's dead...that was a cool board for it's time) and did some photochop on it for illustration. the file is about 500k, sorry for the size, but to get the detail I almost had to.
in the pic, for the trace on the right that's cut, simply scrape off the coating and expose the bare trace. then tin the exposed trace on both sides of the cut, and then either place a small wire (probably 18 gauge or higher) across there and solder...or just drag some solder from one side to the other.
The trace on the left would require a small wire but the same basic operation. expose the trace, tin the exposed trace, then tin the ends of a small piece of wire, solder in place and you're done.
to finish up the job, paint over it with some liquid electrical tape to protect it.
example
super job man TY verry much,if the mobo is dead when i get the vid caed ill do that.thanks verry much again:cool:
bummer man. That sux. Is he gonna buy you a new one?...or least chip in?
A good friend of mine is over nighting me a new mobo till i can beat my boys ass for fucking up this va6.I am looking for a nother va6 right now and i have bid on the only one thats on e bay
did you try the repair on it and it still wouldn't work afterwards? If so, that really sucks.
good luck on it.
I do not have the stuff to work on that fine of a wire so ill have to bag it up and do it some other day..i do love the abit va6,for what it is i love it.not the best mobo on the market but for a slot one it rocks.:cool:
