Abit undervoltage Question
RM_Bulldog
okay in Bios i Set my Voltage to 1.75 the reads though at around 1.69-1.72 @ this setting i know 1.7 or below to stay safe but considering that Abit undervolts do you think im safe with these setting or should i drop it .025 ?
Its very common for the NF7-S to undervolt. its not a bug its a feature :p
Leave the voltage at the lowest stable setting. This reduces heat bigtime. After lowering it, if you experience any instability, then just raise the vcore .25 and test again.
Adjusting voltages isn't super risky, just be patient while testing it and don't run voltages unnecessarily high either.
