abit temp censor
chuckm1020
Do abits over read on there temp sensor. when i had my a7n8x deluxe the idle temp was like 4C lower than it is on the abit nf7s.
I know some of their boards do, but in general, mobo temp sensors shouldn't be taken at face value. They're not super accurate, but they get the job done. My CPU is supposedly 52*C right now, idle, but it's stable----that's the most important thing.
How can you tell it's overreading though? I'm running mine at about 48 c idle, with just a heat pad on though.
1.)Take someones word for it, or
2.)Get a temp sensor that's put right up against the core and use that value.
even with the abit sensor exagerating my cpu temp, i rather read it higher than normal than trust the reading from my koolance.
:rolleyes:
