WuTangClam said:They should work fine. The NF7-S should support all speeds of DDR SDRAM without any problems unless you're overclocked.
The website is incorrect. I am running 3 DIMMS of DDR400 on mine. 2 X 256, and 1 X 512, running Dual Channel.I was going by what the website says, which is a maximum of 2 DIMMs of DDR400.
Yep, the NF7-S page on the Abit website refers to Version 1.x of the NF7-S, which doesn't officially support 400MHz FSB Athlon XP CPU's due to its use of the original stepping of the nForce2 chipset. And when DDR400 memory is run asynchronous to the maximum officially supported 333MHz processor FSB, you can only use two of the three DIMM slots.Sarge said:The website is incorrect. I am running 3 DIMMS of DDR400 on mine. 2 X 256, and 1 X 512, running Dual Channel.
it depends on what speed you want hte fsb to run atimpronto said:so if i got 2x512 3700 they wouldnt work?
lorcani said:You can't run dual channel, with 3 sticks of RAM.
Have you tested this? It doesn't seem possible to me.SIK_L_CELL said:You can if you setup with the two dual sticks, then reboot after you insert the third.
lorcani said:Have you tested this? It doesn't seem possible to me.
SIK_L_CELL said:Dual channel is enabled in the NF7 by using 2 or more dimms and placing one in dimm slot3 and the other in any other dimm slot. Single Channel is active when dimms are in dimm slot1 and dimm slot2. To recap, slot1 and slot2 are one channel and slot3 is the other channel. Although not officially supported, many users successfully run dual channel with 3 dimms. A correct example on how to do this is to have two 256mb dimms in slot1 and slot2 and a 512mb dimm in slot3. Having the dimms closely matched as to manufacturer, speed and batch will increase your chances of running dual channel successfully.
Check out these sites.
http://www.logan.eclipse.co.uk/abit_nf7_(s)_v2_0.htm
http://www.lvcoyote.com/
Zackly! Although you can sometimes get away with the sticks not matching (guess it could vary from board to board). I'm running 2 x 256 Geil Golden Dragon in slots 1 and 2, and 1 x 512 of Kingston Value RAM in slot 3, dual channel.A correct example on how to do this is to have two 256mb dimms in slot1 and slot2 and a 512mb dimm in slot3. Having the dimms closely matched as to manufacturer, speed and batch will increase your chances of running dual channel successfully.
