ok, the north bridge fan on my nf7-s is starting to make noise and i would like to replace it for that reason. the swiftech solution is out due to cost (for right now at least). i am looking at the zalman zm-nb47j right now, but why does the zalman website say
the part that worries me is that they say that you must use one of their cpu coolers. i have a swiftech mcx462-v right now, would that work fine with the cooler?
?1. ZM-NB47J does not require a fan, thus does not need to be powered, and does not generate noise
or vibration.
2. The Northbridge chipset can be cooled to an optimal temperature without generation of noise.
※ Recommended CPU Coolers
CNPS6000 (Socket 462), CNPS6500B (Socket 478), CNPS7000B (Socket 462/478/754/939/940),
and CNPS7700 (Socket 775/478/754/939/940) allow more stable and silent operation.
Compatible Northbridge Chipsets
1. ZM-NB47J is compatible with all Northbridge chipsets that do not have a built-in graphics core.
2. Northbridge chipsets with built-in graphics core are compatible ONLY IF the following conditions
are met.
1) The Northbridge chipset MUST be located between the CPU socket and AGP (or PCle) slot.
2) The CPU cooler must be one of the Recommended CPU Coolers mentioned above.
