abit nf7-s hotkey start up
fillrate
In the bios theres an option for booting up the pc with anykey which i usally use.Theres also an option for hotkey,but what is the hotkey to boot it up?I cant figure it out.
I think "hotkeys" are any keys to which you can assign a function you want to use. Like your internet keys on an internet ready keyboard.
On my Logitech, in the I-Touch software it has a tab for hotkeys, and my 3 internet keys are listed. Not sure what you would have to assign the keys to in order to start your computer, or if it would start when you touched any of them.
Hope this steers you in the right direction.
if i get what your saying..
their's an option to enable booting from a hot key... then theirs another option to assign the hotkey that boots the system..
at least thats how mine is..
As far as im aware you cant have any button (as in any button at one) start your machine.. you have to assing one or two hotkeys
On my NF7-S, there is an option in the BIOS to start with any key, and it works. Don't know if it's available on other boards though. I use it because I have a UPS, which is off when I'm not using my computer. So when I start up the UPS, all I have to do is tap a key to start the computer.
Haven't messed around with the "hot key" option, will have to check it out next time I boot up.
Just rebooted and checked it out.
Just set it to "hot key", then look a couple spots down below that option, and you can set which key you want to use.
You have the option of "Control/F1 through "Control/F12.
