Abit nf7-s chipset fan
tribe
The chipset fan on the heatsink of my abit nf7-s has been grinding on and off and really pissing me off....can i just unplug it ? its a small little fan...and i cant stand the noise. My cpu temp is low, 43 ish and system is always low around 20 -25. The chipset heatsink isnt even warm to the touch...what would turnin off the fan do? Is it safe?
Known issue with that motherboard.
Problem could be the fan hitting the sides or grill of the HS, so just take it off and check to see if it is bent anywhere. You can leave the top grill off I do believe and still screw the fan to the HS.
And I can't say I would suggest just unpluging it, it is there for a reason.
I had that exact same problem. About a week ago, I was testing out a video card, and just decided to unplug that fan just to see what would happen. Since then, everything has been running normally. I haven't even noticed a case temperature difference either.
yeah, this is probably ok if your case temps are low but if not it could cause some instability if his aren't. personally i'd do what the other guy said or just rip the fan off of some old vid. card or something ;)
Those things are hardly a cooling solution without a working fan. There isnt much along the lines of a heatsink. NF2 nb's arent the coolest of nb's. You can go passive, but would not with that thing. All the guys like DFI and asus use much bigger passives and they get warm.
