Abit NF7 Rev 2.0 Seriously Need Help
Cody8417
Ok, so I had a bad board that I RMA'd. But the board they sent back seems to be even worse.
The first thing I've noticed is that the BIOS was from 12-24-2020, which obviously hasn't happened. So I tried to flash from a floppy, however it wouldn't get past the detecting IDE drives on the post screen. So I pulled out all the IDE drives and just left the floppy installed. When it went to boot from the floppy, it gave me a disk unreadable i/o error message.
So, I tried making a bootable cd and flashing with that and plugging in only the cdrom. This worked.
So I tried plugging in all the IDE drives again and its still hanging at "detecting IDE drives" So I unplugged them all except for the hard drive. Here's where things get tricky.
The hard drive motor won't spin up when the IDE cable is plugged in, however when the IDE cable is NOT plugged in, it does spin up. Furthermore it works on my friends computer.
Continuing with the problems, it will sporadically give me the Two-Tone Siren that supposedly means its overheating, but according to the temp monitor and thermal probes its only in the mid 30 c's.
Last night, after a load of fiddling, I did get it to boot into Windows of the drive, but lo and behold, its hanging at detecting IDE again.
I put bios 21 on it and I have a 160gb Maxtor if that means anything to anyone.
Thanks in advance
Chris
Here's my two cents:
1) Do make sure the power supply isn't flaky. Try another one if you can swing it. I've had a few cause problems with various boards.
2) Make sure the CPU is seated properly, and reseat it just for the fun of it. Also, change the fan on the heatsink. (assuming you're air cooling)
3) Try another CPU. The one you have might have been damaged while on the board you RMA'd.
4) Make sure you reset the bios after flashing. Then enter the bios screen and turn off all the stuff that isn't neccessary for basic functionality.
5) Try reseating the RAM or using different RAM. Perhaps use only one stick if you're normally using two.
6) Do try different IDE cables just in case your cable(s) are causing issues. Do you have a different hard drive you can hook up?
If nothing above works, your board is no good. Hope that helps.
