Sanitarium
- Feb 3, 2004
I have an Antec Smart Blue 350 and it has a connector to connect to your motherboard's fan header to adjust it's fan speed according to your system's temp. Well I've connected it fine and everything, but when I go into AbitEQ to check it's fan speed it shows up as being off. Is this just a problem with AbitEQ or what? Are there any other programs that will monitor your power supply's fan speed? Thanks.
