Abit NF7 - Computer Not Posting
medium
Hey everyone,
I ran into some trouble with my computer. It's really upsetting because it's probably going to lead to large upgrade...
Late last week, I tried to bring my computer out of sleep mode only to find that I could not.
No video signal, mouse and keyboard led's off - So, I tried a cold reboot, thinking it would fix the problem.
Now the computer won't post at all. No power to peripherals, no video signal, no on-board beeps.
I've tried switching motherboards as well with no improvement. Although, it may be just my luck that both motherboards are bad. Before I made this thread, I did a little digging on old posts about similar issues. Some suggested piece-by-piece boot up attempts (booting up without any devices / cpu / memory). I haven't had a chance to run this method completely, but I did take out the ram to listen for certain beep codes - nothing came.
I've also tried 2 different power supplies. It should also be noted, I was able to recover from this problem ONCE! by clearing the CMOS. That doesn't work either now.
What do you guys think? Do I have TWO toasted motherboards? I know the hardware is old, but I want to hear your thoughts on this. Your wisdom and input is greatly appreciated!
Abit NF7 / Abit NF7-S
Athlon XP 3200
1gb corsair value select
scythe gouriki 450w psu / enermax noisetaker 420w
you sure you don't just have a bad power cable, surge protector, or outlet? Seems kind of weird that it happened on two different boards with two different power supplies.
If you feel comfortable, I'd try to power the motherboard up outside of the case if you have it out. Maybe something is grounding the motherboard improperly -- like maybe a standoff or a screw somewhere...
the computer's power is runs into a simple expansion pad from an outlet on my wall. other things run fine from it.
i took out almost half the computer when i switched motherboards, but i suppose powering the whole system out of the case might be the best way to know for sure what isn't working.
i'm convinced that it is a broken part and not a matter of something being grounded because i did not move the computer overnight.
Test the PSU first.. Unplug it from everything, plug in a old HDD or two, and plug it in. On the 20pin connector there should be one green wire towards the center of the connector. If you short that out to one of the black wires with a paperclip it should make the PSU turn on and spin up the drive.
First thing I'd check, the fuse in the power cord, then I'd switch wall sockets & multipoint adaptors. After that, you might want to get a multi-meter and check the PSU to see if it's outputting correctly.
try taking the battery out for a half hour, this sometimes works with nf2 boards
thanks to all for your replies,
It's probably also good to add that in the history of owning this computer, I've tended to leave it on for extended periods of time (go on for days without a reboot), if that suggests any considerable shortening of life-span to certain computer parts...
I'm afraid I don't own a multi-meter nor have the confidence to short any kind of circuits on my computer myself. However, I'll begin with removing everything from the computer and doing piece-by-piece boot up attempts. I'll also try a different power cord to see if it helps, also will try removing the button battery and leaving the CMOS jumper on 'clear' for about an hour and see what happens.
wish me luck. (but then again, a new computer would be nice :rolleyes: )
