abit mobos conflicting with psus
Mizugori
i just got the rest of my parts today, so i tried to assemble my new pc but no go. i am using a nf7-s mobo so i checked on abit forums after hours of trial and error, i noticed that many people suggest that generic and cheap PSU's don't work with abit motherboards. many also indicated that a new name-brand psu solved their problem. any information on this? personal experience?
thanks!
generally a cheapo psu isn't worth it's weight (and they're light too). Power supplies to me are the unsung heros of the computer, they do all the work and get partically no credit. Generally is if you spend money on a good psu it'll last you around 5 yrs while a generic will probably burn out in less time than that, i do not really know how long generics live as i don't use them much. Do yourself a favor and just buy a name brand one (antec, enermax(my favorite), and a few others), buying a name brand one generally causes less headaches and you can most of the time eliminate the power supply as the problem, if you ever have one.
well thanks for the lecture preacher orsk :rolleyes:
i actually know a fair amount about PSU's, and i have a nice antec true on the way. My question was about using generic psus with abit products not just in general.
and btw plenty of members around here would tell you that they have had great success with cheap PSU's; especially if you aren't overclocking (or at least not incredibly high)
I don't see why Abit boards would have problems with generic PSUs unless they're particularly picky about the supplied voltages (which a mainboard shouldn't be).
Sure, there are some lousy generic PSUs out there, but these are likely to fail to work with/blow up any connected hardware, not just Abit mainboards.
I also have seen a lot of gripes about the NF7 series and cheap PSUs. I don't think it's an issue on all Abit boards, but the NF7 seems to be picky about PSU quality.
well well well, what a surprise just my luck PSU guy tells me today that he didnt ship on the 17th as he had said he would, but "will try to today"
fuck that im driving my ass down to best buy right now, its an hour but i dont care at this point. jesus. nothing like poor business to ruin my day
ill report back and tell you guys if the new antec solves the problem!
Cheap power supplies just don't push the voltages and the amps of the name brand ones in alot of cases.
Cheap ass PSU's though should only affect your machine if your maxing out the 12v rails. Or are close to it.
My machine is a good example. I would doubt that some off the shelf 300watt PSU would run the machine in my sig.
I had an NF7 that refused to boot with the crappo Powmax that came with the case. I had a Turbolink 420 laying around and that did the trick. The Turbolink definately isn't a "good" psu, but it's leagues better than the Powmax
A quality PSU is more than just available current, it's clean power on all the rails. A lot of cheap PSUs can supply the juice, but have ripple or noise on the voltage rails. Some mobos care more about that than others, and so don't run well. This seems to be the case with the NF7.
well it actually didnt solve the problem so im getting a refund and i ordered another board lol. ill keep you updated.
