Abit Mobo Problem
v8_h8r
Ok were to begin. I have the Abit KV8 Pro and about a month ago i turned of my pc and it would not turn back on or give video signal. So i thought that the video card was a goner. Well low and behold i try all my hardware in another pc and everything works fine, so mobo was the prob. Well i get newegg to RMA it and i finally get it back 2 days ago. Well i put it all back together and it still wont give a video signal but this time the mobo is hanging on 0.4 code. Now I searched for this code on abit's website since its not in the book and came up empty handed. I did however find a post with a person having the same problem as me. He said that he pulled a stick of memory out and it worked. so i tried this and my pc fired right up. Also the guy said his ps wasnt enuff juice for his abit system. Well i thought that is what fried my mobo so i just happened to order a Enermax 430w ps. So i rule this factor out. well i turn off my pc and stick the other stick of ram in it and it fires right up no problems. so i go 2 days without a problem and my computer just starts restarting over and over again. then throws up a blank screen with the wierdest gibberish language ive ever seen. I turn my pc off and it wont come back on. So i pull a stick of ram and it starts fine. So now i try switching sticks to c if the memory is bad and both work fine individually. So i have reinstalled windows and have not a fukn clue what the problem is. anyone else have this prob? here are my specs
Abit KV8 Pro
A64 2800+
Venus 12 Heatsink and fan
Geil Ultra Series PC3200 2x512
ATI Radeon 9700 Pro 128
Sound Blaster Live 5.1
1x 80gb WD 7200 8mb
1x120gb Samsung 7200 8mb
Enermax Noisetaker 430W PS
i had a problem with restarting on an NF7-S 2.0. my computer would turn on and get into windows just fine. then at random times it would restart.turns out the ram was bad (2000+ errors).
maybe you can run memtest?
im sorry, but i didnt have the same code as you.
however, i do have the kv8pro also. it has given me many problems and a code that isn''t in the manual. i visited abits forum and there were a total of 60 posts about the code and no one knew. its been a few months now without and problems, so i cant remember the code!
i did the only thing i knew to do. i broke it all down, cleared the cmos, and put it back together.
since then, the only problem is it takes a while to boot up (i mean the first few times i press the power button, it starts up and turns off after 3 seconds) after a power-outage or my two year-old flicks the switch on my power strip.
ive just given up on abit and am going to order a new mobo the next time it nerfs on me.
Have either one of you 2 flashed the BIOS. Also is your memory on Abit's recommend list that will work with that board. The wife & I both upgraded right before Thanksgiving to this board with an 3400 & neither of us have had any problems. She's running Corsair ram & I'm running Crucial. Both of us have 2 512mb sticks. I've flashed the Bios on mine but she's still on the older version. I upgraded her 1st & we both were so pleased with this board that I upgraded about 2 weeks later. My only complaint is that my Crucial is not the (high quality stuff just stock PC3200 ) so I can't overclock worth a hoot. My other gripe is that no matter which version of the uGuru software I install It starts acting all wierd & everynow & then It will lockup. I just uninstalled it & everything has been smooth sailing for over a month.
I also have this board and have found when i had my previous problems with my board that a few codes appeared that werent in my manual :rolleyes:
Hope you get this problem sorted!
i reinstalled and flashed cmos and it seems to work fine now... but alot of people are having same problem and say that it is do to mobo warping. check ur OTES heatsink attachment and make sure its not too tight and your ATX mobo screws. also it seemed like the DIMM slot the ram is in is loose? i can move it back and forth but i cant with DIMM1. Seems like shotty work. as long as i dont have a problem for awhile im ok but if it fuks up im gonna bitch til i get them to buy me a diff mobo prolly from a different company
