abit mobo fried?
ssmith500
i gotta ask if what i just did ruined my mobo. i have an abit ai7 mobo and recently the northbridge or southbridge (i forgot which one it was) heatsink/fan has been making a lot of excess noise. i go and shut the computer down and almost immediatly after removed the heat sink in order to remove the fan and get all the dust out. after cleaning and reassembling i re attach the heatsink to the mobo, turn the comp on, but there is no display and basically no startup. hdd lights go on, cd light goes on, fans turn on but absultoly no beeps or basic startup....
my question...did i remove the heatsink/fan off the chip on the mobo too quickly after shutting down causing the chip to burnout? is that possible?
it is possible... but unlikely.
more likely, you jarred something loose when you were in the case.
Re-seat your video card, memory, and mobo power connector.
yeah i tried that, didnt work...its funny cause i thought a burnt chip on the mobo would cause a burning odor but it didnt... and the mobo and comp still turns on in the sense that the hdd light goes one, bay drive lights and lights on the mobo but there is no actual startup or display. i dont know what to do
Abit is involved in a class action lawsuit for blown capacitors, among other things. So if I were you, I'd look into that.
I also recommend that you stay away from Abit from now on.
Ralliart Evo
I have been having a similar problem, however I thought mine was video card related, but I have the same symptoms as you. I also have an Abit motherboard model KX7-333, got it about 2-3 years ago.
Here's a link to my post about my issue, do you think the mobo might be the problem instead?
http://hardforum.com/showthread.php?t=868867
First off, when you turn off the computer power stops going through it. So this would stop any more heat from being generated. So there is pretty much no way you could've burnt something.
Second, the Abit capacitor issue was resolved a while ago, so unless the motherboard is one of the models in the lawsuit, I doubt its the caps. But you still should check, they would look like a dark grease coming outta the bottom of a cap. Also check for anything loose and etc.
But as far as staying away from Abit, thats uncalled for. I have an NF7s, along with thousands of other people, and not a single problem. Abit makes a good mobo. My last MSI died, but I dont blame them. Stuff happens.
You might also try to clear the CMOS. The jumper should be listed in your manual.
i basically did everything i coulda done... cleared the cmos jumper, took the mobo battery out for a minute. its funny cause the comp was working perfectly normal for the longest time then all i did was remove the heatsink/fan, cleaned the dirt, put it back on and it doesnt start up again.
any other ideas?
Have you tried booting your computer with a PCI video card? Sometimes the NF2 boards have a "cold boot" problem; they don't boot properly because they don't interact with the video bus the right way. Also, have you taken EVERYTHING that is non-essential out of your case, and then reseating that which is essential, and seeing if that works? It's quite possible something or other got loose, ie your RAM or something, and it just needs to be put back in place. It's unlikely that removing the northbridge cooler is responsible for your problem. Also, if you have access to another computer, test all your bits in the other computer to make sure nothing of yours is toasted.
