This is my Temp monitoring:
Reading Beep temp
CPU 103c/217f 75c/167F
system 35c/95f 55c/131f
Obviously, cpu is the issue here. This is a new CPU (RMA'd from intel)
I am not OC'ing. This is idle temps. I checked the intel stock heatsink, it is really on there. The cover is off the case as well. Why is this thing running so hot or maybe it is misreading the temp?
This is a core 2 duo 8400.
I can get in to Windows and it seems fine. I even got through a chkdsk. It isnt crashing.
Is there anything I can run that can read the correct cpu temp in Windows or will it just use the sensor in the bios?
Reading Beep temp
