Abit KV8 Max 3 Noise
Robolf
Im wanting input from those of you who have this board.
I have a virtually silent PC at the mo and am going the A64 route i would like to know peoples views on this board and how noisey OTES and the N/B fan are, ive read that FanEQ will slow these down from the BIOS and i have a really Cool case setup with 4 fans plus PSU in virtual silence.
So my question, with the Bios using FanEQ can you make this board silent except for the most demanding times when it will kick the speeds back up?
Thanks for you help, i guess if this doesnt work i will get an Asus K8V as it has a passive N/B heatsink.
Rob
i <3 love my Abit board! i haven't tried my fan EQ stuff but it's a nice board and it is not loud at all. i don't know how much you know about the board, but with the fan EQ you can adjust the speed based on the temps of the NB and the OTES. you set low temp and a high temp, if the temp goes above that setting the fan will go to the voltage you set (ie: 12v, 8v). i will go try it to see how it works and i will let you know.
edit: just tried FanEQ, works great. can't really tell much difference in noise, but i have a couple loud fans that overpower the rest of them!
thanks for the reply, dont suppose you can silence the fans temporarily and tell me how load OTES and NB are.
yes ive read all about FAN EQ but my current setup really is whisper quiet and i dont want to ruin that unless i need to to play a stressfull game which then i hope the sounds of killing many people will drown out any high speed fan action.
this is the board i really want for the feature set, as im upgrading my second pc and this will basically be with this board for years after this, and i will only upgrade my main pc, or move this to my main after it proves itself, just cant be arsed reinstalling windows.
if the FAN EQ does indeed make the board silent most of the time then thats me sold, just some reviews have said about noisy OTES and NB fans, i think a few early NB fans were broke and very noisy.
i dont want to buy and new NB HSF and 40mm fan for OTES on top of the 115 pounds for the board in the first place, by the way did your board come with a HSF retention bracket? i will probs use a Zalman 7000A-AlCu so i dont think i need it but just incase i decide otherwise....
I can't comment on the Northbridge fan (I removed the HSF in favor of a waterblock), but the OTES is a noisy POS. Once it warms up it isn't bad, but its the only thing in my PC that I can hear and it is annoying. Its not so much the noise from the speed of the fan, as the noise of the fan rattling.
i cant understand why abit cheap out on the fans, ive heard many reviewers say they had noisy fans, the one on my nf7-s got dumped because it was too noisy, and back on my kt-7 i got rid too. i was hoping for better news from the new board but i guess unless someone can tell me for sure that FAN EQ will silence both fans while im just surfing the web i will go with the asus.
I can'tsay much about the KV8-MAX3 (well, I will be able to next week), but the IC7-MAX3 is a bit noisier than Antec's Sonata case witht he fans at full tilt, however, when knocked down to 70% with their fan controller (whatever its called), the fans can no longer be heard.
thanks for the imput thats good to k, only thing is i planned on using a Zalman 7000A-AlCu and 2 sticks of Corsair XMS3200C2 that i have but apparently the Zalman heatsink blockes the first DIMM and u cant use the third DIMM at DDR400 speed, bugger.
So ill either have to get a Thermaltake Silent Boost, or if someone can suggest something better? I was under the impression that the Zalman was THE cooler to have, plus it doesnt need the retention bracket that doesnt even come with this Abit board.
Any input appreciated.
Rob
Rob
Actually since rev 1.2 the retention bracket has been included with the KV8-MAX3. I guess they realized that thier target market was very likely to purchase OEM processors...either that or all the people bitching about it on thier forum woke them up..
