abit is7 question
Hazards
i just bouhgt a 2.4c, and the board i got kinds blows ( i can only oc to 2.75 and evn then prime95 isnt stable) and the only thing i can think of is the mobo. its the dfi ps83-bl(kinda cheap). 1 gb corsair xms 3200 twinx. so i did some research on good mobos and the abit is7 seems to be a decent performer. (someone correct me if there is a better alternative <$100) my question is what is the differance between all the is7's on newegg?
http://www.newegg.com/app/searchPro...hFor=abit is7
those are what im finding.
That page links to nothing when I click but........
But I had the IS7 regular and I got to 3.2 on a 2.4C. Some AS5 or something woulda been helpful cuz after a few months i coudlnt keep it P95 stable.
IS7-G has Gigabit ethernet and possibly other stuff.
I dunno about the V M or whatever other letters they have for it.
i like the board...and i got the lowest model. the IS7-E2, my northbridge isn't even actively cooled, well now it is, i just stuck a 80mm and pointed it at the NB...
Anyway...My only gripes about the "E2" model is:
1) No active cooling on NB
2) Voltage reg for CPU is unstable.
- ie: Vcore right now is set at 1.7V in the bios, at idle, it sits at 1.7v, but as soon as it loads down it drops to ~1.65v. Now I'm no the most experience OCer so i'm not sure if all mobo's are liek this, but my proc is stable at 2.5ghz @ 1.7V under load**. But since the voltage reg dips down under load, in order to get 1.7v under load, to compensate i have to set the bios at 1.75v...and thats too much juice for my liking and the extra 100mhz isn't worth it to me.
Other than that the board is solid. I bought this board solely to avoid upgrading my processor for a little bit longer. My last board sucked butt(MSI 845 Ultra-AR) and it wouldn't let me get past 2.1ghz. Bought this board and OC jumped to 2.45ghz @ 1.7vcore(bios), i can get 2.6ghz @ 1.85Vcore....but i'm keeping my cap at 1.7vcore.
Anywhoo... in addition i like the fact that along with nice OC abilities, it supports all of intels procs up to the most recent 800fsb procs...so i still have room to upgrade later.
But i dunno dude...i been lookin around, looks like the scene is changing...might wan't to hold out a little. There a bunch of technology transitions happening right now...PCI-X and socket configurations, and S-ata...
also..i'm not sure what happen to this board...
just becasue my "status says": newbie, i'm an old school visitor to the hard forums....
and the usefulness of the board since back in the day...has gone way down....
Doesn't see like anyones willing to help out with the "simple questions" anymore. Search my a**, the dumb thing is very ineffective with that "search every 60 seconds" bussiness...
get the is7g if you need gigabit ethernet, otherwise get the is7 regular or even the newer ai7. my only gripe with the vanilla is7 is that i can only put my ddr voltage up to 2.8 max. good board for the price though.
forgot...yeah 2.8v to the mem kinda low...but my mem is running underclocked right now so i don't have vmem issues...
ratios are 1:1, 3:2,: 3:4, 4:5, & 5:4
if you run into troubles ocing, make your GAT settings to auto, normal, auto, disabled, disabled. that seems to be teh thing that holds most people back with the is7/ic7
I had an IS7, P4P800-Dx, and now an AI7. Out of the three, I'd have to say that it's a toss-up between the AI7 and the P4P800-Dx.
The p4p800 had a fluctiating vcore when under heavy load (vcore would drop...which isn't too good for stability in overclocking). With the droop mod, it worked great.
The AI7 has rock solid voltages, and plenty of overclocking options. more than the p4p800 did. The uGuru is more of a gimmick than anything. the auto fan control and fan voltage adjustments are kinda cool though. I don't use their uGuru software either b/c MBM 5 supports the AI7 and uses less resources.
If you're looking for comparative boards, you should also check out the Epox 4PDA2+. I was about ready to sell my AI7, and get the EPOX board but then I decided I may switch to an A64 system for awhile and give it a shot.
