Abit IS7 and intel Prescott
J
Jammer8
Guest
I have an IS7 Motherboard and i was wondering if it will handle intel's new prescott 2.8GHz cpu........if anyone knows for sure it would help alot........thanks
I think Abit has a beta bios for the IS7 to run prescott. Check Abit's forum for the file.
Even if it supports it i wouldn't run one of them on that board. The board cannot supply the kinds of voltages the MAX3 can. In reviews of boards used with the Prescotts they overclocked well but the motherboards got very hot while running the processor. I would not suggest buying a Prescott now. Wait till there are new Grantsdale chipset boards out to support Prescott because the boards will be designed for Prescott and be able to handle its power requirements better.
