i can't get it to detect my ide dvdburner, so i can install windows.
i changed cables 3x now, as well as made sure the dvdburner was
set to master as well as cable reset. i even borrowed the dvdburner
that i know is working from my other pc and still the same thing.
the jmicro section shows no devices detected.
the manual doesn't help at all in regards to
troubleshooting ide stuff.
i've already cleared the bios numerous times, and flashed
to the 14 bios hoping it would work. any thoughts?
(outside of buying an sata burner?)
do i just have a bad ide controller on my new board?
