abit ip35 pro usb not working :O(
osok11
i just installed xp pro x64 and my mouse and keyboard (both connected by usb) worked fine but when i installed the abit driver cd anything connected to the USB does not work. When i check the device manager it shows ROOT USB HUB with a yellow ! any ideas?
If it worked before I would insert the Windows disc and update the drivers from device manager, making sure to choose the MS ones from the list.
i tried updating drivers from the windows disk and the abit disk but to no avail
can you roll back to before you loaded the USB drivers from the abit disk?
Just uninstall all the USB devices with yellow ! in device manager, reboot and it should sort itself.
happend with me, XP and IP35-E but that fix should work for you
omg thank you so much finally i got this thing running in tiptop shape:D
