Abit IP35-Pro & Scythe Fan
bigdavethehorn
I started building my new PC last night, and I'm wondering where to plug in my Scythe S-Flex SFF21F fan, the fan cable has 3 pins, whereas the CPU fan header on the mobo has 4 pins.
Can I use one of the AUX fan headers or will the draw from the fan damage the mobo?
They have their own MOSFETs, and are supposed to be ok even for a 200mm fan.
I've not see any actual numbers, though.
the CPUFan header will accept a 3-pin plug & it's keyed so that it can only fit 1 way.
If you do choose to use another header make sure to disable the low fan rpm warning & shutdown for the CPUFan header.
the header is keyed so that the plug will only fit across 3 pins in 1 way.
