Abit IP35 pro, on boot usb keyboard doesn't work.
enyceexdanny
Hey guys. I setup my new rig today, but during the boot process my usb keyboard doesn't seem to respond. When I use my ps2 keyboard it works fine.
Also, my sound card (audigy 2 zs) dies out of nowhere and my network card too..
Maybe the board is defective? >_>
Any ideas?
Thanks.
In the Bios, change the USB settings from OS > Bios. You'll have your keyboard during boot until control is passed to the OS.
Also in the Bios, make sure the onboard HD Audio is Disabled, and that the Network is Enabled (should be by default). While there Disable the Firewire headers so they don't conflict with what is on your Audigy 2 (if I remember correctly, the Audigy 2 comes with an integrated firewire connector, right?).
* On the IP35 Pro, the Realtek Network Chips are on the PCI bus, as would be your Audigy 2 and onboard audio, so... a conflict with audigy 2 vs. onboard sound, or motherboard's firewire vs. Audigy 2's firewire might cause your Network to get caught in the conflict.
Try those and check back to let us know how it is working. :)
you don't have a PCI Bus, you probably blew a cap.
USB, PCI and Network are all on the PCI bus.
I did change the settings for the USB to bios.
Seems to work, but not all the time (?)
Well, my network and sound only seems to die when I have my external firewire hard drive connected to my sound blaster port.
All the onboard sound, and ethernet is disabled.
When I tried disabling the onboard firewire controller, and plug the ext. drive to the sb firewire - it kills my sound.
But when I have the onboard firewire on, and connect it to that. It seems fine.
It's just kinda odd.. Wondering is anything's wrong with my mobo...
Thanks again guys.
Yep, sounds like you had/have a conflict. The motherboard shouldn't care if you have two firewire from two different sources, but I suggest you Enable the onboard firewire and use that (i.e., connect the device to the motherboard's extension bracket) instead of the one that comes onboard the Audigy2.
There are two red-colored pin headers just below the Primary PCIE x16 slot (you might have to remove your graphics card to connect the cable if your graphics card uses a two-slot cooler).
You have two choices for the connection: 1. A firewire connector that is integrated into your case, usually connected in front. 2. Abit supplied a PCI-bracket that has both firewire and additional USB breakouts. I suggest using the latter.
* Remove your graphics card,
* choose a free PCI slot to install the bracket so connections can be made from the back of the case, outside.
* Connect the bracket's two firewire connectors to the two red headers on your motherboard.
* Reinstall your graphics card back into the primary PCIE X16 slot you just removed it from. Take care at this point that you do not displace the firewire extension bracket you just connected! (I know the placement sucks just under the graphics card cooler, but many motherboards are putting it there now. It'll fit, I've tried, just move slowly and carefully)
Nothing's wrong with the board. It's just that that PCI lane is being asked to handle more data than it is capable of managing, kind of like morning rush hour on an older road. Just use the onboard firewire for external connections, onboard Network, and the Audigy2 for sound w/ onboard sound Disabled. That way you shouldn't have an issue.
