Abit IP35 Pro HSF?
A Shiny Demon
I'm considering purchasing an IP35 Pro from Newegg ($150 after rebates, seems like a better deal than the P5K-E for the dual-LAN and optical-input) but I want to make sure my cnps-7700 will fit on it first. There are two issues:
1. There is a MASSIVE-looking heatsink on the northbridge, and I have no clue whether or not the big 'ol Zalman will clear it.
2. I have a small case, and the top of my motherboard almost literally touches the bottom of my PSU. The CPU socket is fairly low on my current A8N32-SLI, but it seems to be higher on the IP35. Does anyone know the distance from the center of the CPU socket to the top of the IP35?
If you all think I would have better luck posting in the cooling forum, let me know. As always, any input is much appreciated.
For the first question.. I asked the same thing on the abit forums before, and i was told that the 7700 will clear the northbridge.
