Abit IP35 Pro & electrical noise?
Psychor
Hi all.
My issue? I recently built a new rig (parts below) and I’m noticing a decent amount of electrical noise coming from the system when powered on. It seems to originate from both my video card and motherboard.
For instance, when I'm in the BIOS I'll occasionally here noise from the motherboard (e.g., buzz). It’s not always constant though. While clicking on a certain button in RivaTuner (how random is this) I'll notice my video card emits a faint noise (e.g., buzz/beep). Generally speaking the video card will emits noise when called into action (e.g., when running 3DMark06). This are just a few examples.
Intel Q6600 G0 @ 3.0 GHZ (333x9)
Thermalright Ultra 120 Extreme
4 x 1GB Corsair XMS2 DDR2-800 @ 2.1v @ 4-4-4-12
Abit IP35 Pro 1.1
PNY 8800GTS 512MB G92 (cores overclocked ~ 10%)
Corsair 520W PSU
*Prime95 and Memtest86+ tested.
My question is how irregular does this sound? I never really noticed any of these issues when building/using my previous AMD 939 rig which used the exact same video card and PSU (swapped them over to the new system). This reminds me of my old SoundBlaster and the snack, crackle, pop when scrolling in IE. Haha.
Thanks!
My G92 GTS does it sometimes. I know for it does it during ATI Tool artifact scanner, so I'm sure it does it during other 3D apps as well. It's normal... your PSU is fine (before some comes in and says your card isn't receiving adequate power, I pull <300W off the wall during Crysis with my overclocks) so it's really just a slight annoyance you'll have to live with.
As far as it doing it in the BIOS screen, or doing 2D idle operation, you might have something going on. I've never heard any of my past video cards make buzzing noises in 2D idle that did it in 3D operation.
The thing about the BIOS issue is that the noise in that instance does not seem to originate from the video card but the motherboard itself. I imagine it's some combination of caps, resistors and/or inductors. The more I dig into this the more it doesn't seem that out of place. None the less any and all information is greatly appreciates. Thanks.
lots of mobos/gfx cards make noise - it usually comes from the PWM section & is down to inductors or caps.
Exactly right, and if it bothers you enough a little sleuthing around with a homemade stethoscope. A soda straw or rubber tubing carefully jammed in one ear with a finger in the other and a dab of RTV adhesive will usually calm down the offending component. The case/body of something is happening to "ring" to a lower audible harmonic of the switching frequency of the power supply (board or card supply not the main supply - but components in there are notorious for "squealing" too). Dont smother the part in goop you do not want it to overheat. You can verify you have the right part by touching it with a wooden probe and see if it shuts up. Then a dab of something to keep it from vibrating even just hot wax.
I took your advise and while my rolled paper sheet didn't do the trick luck did. Hehe. The high pitched whine is coming from the motherboards Foxconn keyboard/mouse port (the silver box on the motherboard that houses the PS/2 ports). I noticed that if I held my finger down on the silver box the sound definitely stopped. :eek: Now how to fix the damn thing without RMAing the board. I'm tempted to just rip it off. Haha.
The 8800 still makes noise but the more I read about it the more it seems fairly normal.
