Abit IP35-E weird kb boot issue
So, I've got an
IP35-E
2 Gigs Patriot Extreme
EVGA 8800 GT
Corsair 620 PSU
Basically on boot it will allow me into the BIOS settings, and the keyboard(USB) will work at the very beginning of the boot process. However, by the time it passes the POST when it gets to asking me to press any key to boot from the CD ROM the keyboard is unresponsive.
Obviously I can't load XP this way.
So I hooked up an external HDD(USB) and set the boot order in the BIOS to boot that hoping perhaps I'd be able to run Ghost off of it(it's got images from my work on it) and install XP in my new computer.
Well, the USB HDD boots just fine and pulls up the menu system I'd put in a BAT file on the HDD but still no Keyboard availability so I can't install an OS this way either.
I'd actually installed XP on this machine before so I know the KB worked, but was installing a different version of XP on it(x64).
Now I can't get anything installed on it!
I am going to go buy a PS2 KB to try that out, but in the meantime do you guys have any suggestions?
I've cleared and reset the CMOS more than once...double checked all my conncections.
I appreciate any ideas in advance.
*sigh, the call of duty 4 box is tormenting me.
You didn't get one of those USB to PS2 adapters?
I got like 20 of those in my closet from being included w/ keyboards and mice...
I have a similar problem on my Asus AMD board with legacy USB BIOS support enabled.
I can get into the CMOS with my USB keyboard but once there it doesnt respond.
I made the following odd observations:
If I plug in a PS2 keyboard and get into the CMOS using the PS2 keyboards DEL key, the USB keyboard and the PS2 keyboard both work fine in the CMOS.
If I use the DEL key on the USB keyboard to get into the CMOS, neither keyboard works in the CMOS.
Weird!
I had the same problem. I just used an old ps2 keyboard to get it past that screen to install XP
