Abit ip35-e problems again
brhinton89
Just got a abit ip35-e and when i install it everything shows when i boot up but the dvd-rom, :confused: and everything just stops right there because i cant load any software period. I tried to reformat (boot from cd in the BIOS)but the dvd is not showing up. So how do i get the dvd to show?
Probably a noob question but, did you connect a molex to it? Also, check to make sure the cable is seated completely (sata or ide). You should be able to select boot from CDROM or whatever in the bios, I dont remember off hand and dont have the manual with me. Also, when trying to boot from an optical device, I find it sometimes necessary to disable any other boot devices in there.
what type of ODD (SATA or PATA)?
Also, if you scroll down through the boot priority does it perhaps show up by unique device name (rather than generic CD-ROM etc.) something like 2nd or 3rd from bottom?
