Abit IP35-e PCI latency
Ferris
I'm in a bit of a dilemma with my IP35-e. In the bios there is no option to change the PCI latency and I think it may be necessary for me to do so. I have a X-fi sound card and there seems to be a little bit of crackling when I play COD 4. Everything else runs just fine with the card and there is no crackling.
I have been told that changing the PCI latency will help my situation. Unfortunately this is easier said than done. I have no option to do so in the bios, so I attempted to use "PCI latency tool," but this causes my computer to hang. I am using Vista 32 and the latest bios available from Abit.
Does anybody have a suggestion on what I can do to adjust my PCI latency to eliminate that as the cause of my problem? Also, any other suggestions on how to remedy my situation would be greatly appreciated if you feel that the PCI latency isn't the problem let me know please. Thanks.
