Abit IP35 doesn't power on
SNaray8442
Put together my new system with a Q6600 processor, IP35, antec earthwatts 430w psu, 2gb of corsair xms2 memory today, but when I went to power it on, nothing happened. When the psu switch is turned on, the red LED comes on, but nothing changes when I hit the power button? What can I try, or is the motherboard DOA?
For completeness what gfx card do you have ?
if you aren't getting the green vcc light or fans spinning I would be looking towards the PSU, a wrongly connected cable or a short in the first instance.
Once you get this resolved I suggest you buy a more powerful PSU since 430w is barely enough to power those components :s
This happened to me recently. Did you try booting with no drives plugged in?
Yah, make sure you have all the cables to the mobo plugged in, ATX 24-pin and 4pin ATX12V P4 connector (to power the CPU).
