Abit IP-35 Pro Problem?
Rustynuts
Old PC, but my son uses it a lot. It boots normally, no weird codes/beeps, gets into Windows for a few minutes, then abruptly dies, no warnings/beeps, etc. The motherboard still seems to have power, all fans are working before the crash happens, and I did a thorough cleaning. When it happens the LED goes from the normal "F.F." code to just "F." and the red power LED goes off. After a minute it all goes back to red power LED on and LED code to "0.0." which is normal and ready for boot.
Power supply problem? But why does MB still show power? (at least on the LED). Bad seat on the CPU cooler? CPU flaking out?
Even does the power off while in the BIOS setup menus. Could a CMOS battery do this?
Nah I don't think so.I would definitely try a different psu.Also It might be a good idea too remove the motherboard from the case and trying it too be sure it's not shorting out some where.
I doubt it's a short? System has been running stable for years with zero issues. I too am betting on PSU. Just waiting on vendor to respond for warranty.
Now when I get these shutdowns the MB shows a code of "F. blank" and I can't find this code in the manual. All the codes are TWO DIGITS!? The "F" code stays there (and won't reboot) until I physically power off the MB and then I get the normal state "0.0" code and I can try a reboot again.
"Event viewer"?? Not sure what that is. I'm not even getting to Windows if that is a log file or something.
Well screw PC Power & Cooling. Spent good money on this thing and it fails almost literally right after warranty runs out? Lame. :rolleyes:
Sorry, I thought you were.
So you're sure it's the PS?
