Abit IN9 // 68i overclock
Hello,
I'm running an Abit IN9, I've gotten it to post and run at 1500fsb. That's pretty disappointing considering I've got an e6850 and that's only 3375mhz cpu.
I'm wondering what's the max overclock you've gotten from this board, or from other 680i boards.
If you've got an IN9 32X it should be capable of far higher than that but you'll need to cool the nb & mosfets as well as of course the CPU.
460FSB max on rig in sig. I think its pretty safe to say the board is holding you back, as 375FSB on an E6850 is the lowest I've seen by far, and I've seen ~500FSB from the IN9. You'll probably need to replace the thermal pads on all the heatsinks (except the PWM, as I've heard it won't make proper contact with paste) and have active cooling on the NB at least, but you might just have a bad board.
Edit: Its also very common for a 680i to have FSB holes. Try bumping it up to 425 or so.
Do FSB holes have to do with the clock generator? Or is it something random?
I'm confident that I can add a NB water cooler to my loop, but there is no clearance under my video card to install a SB waterblock. What kind of cooler would you recommend for the SB?
Also the motherboard heatpipe which covers the NB/SB extends up to the cpu area where there is a radiator right next to my ps2 ports. I have no idea what it is cooling there or how to cool it if I do strip the pipe. Any thoughts on this?
It's cooling the PWM.
If you are wc & have no airflow in that area that may well be your problem.
You have to activly cool the PWMs to run decent overclocks on the IN9. I would also still recommend the 12b3 bios as Abit seems to pretty much abandoned this board for bios support.
