Guys, I'm sure you've heard this story more than once.. Have an IC7, the NB fan starts to sound like a dieing cat once in a while, I need to either replace it or find a NB sink that'll cool it enough so I can go fanless which I would rather do. Can anyone suggest a solution for the latter, I'd prefer no annoying fans. I do NOT OC so it doesn't need to work wonders, I HAVE searched newegg for different chipset HSF's but it's impossible to know if it will fit or work well with that mobo.
thanks
thanks
