Abit IC7 MAX3
AtomicFire
Is there a reason why suddenly it is almost impossible to buy this mobo? discontinued?
I just looked at 2 of my fav. sites, newegg and excaliberpc, and its not there at all. :confused:
Yeah it's discontinued. Abit has moved on to newer sockets and chipsets. If you want a decent socket 478 board give the Abit AI7 a look. I've seen it highly recommended in many places, and it lacks the VTT voltage issues that the IC7 line suffered from. It may or may not have the temperature sensor set right, but that's less important.
What features did the Max3 have that you were looking for? I've been happy with mine aside from the VTT issue. There is a mod for it though, and I've almost finished mine (lazy), but out of the box above 2.8Vdimm is bad.
the name, the quality and the speed
i've built about 4 computers for sale in th epast with them, and now I finally can afford to build my own and now I can't find the mobo
Only the IC7-MAX3 is discontinued? I see plenty of IC7-G's around for sale
I just bought my IC7-Max 3 a couple of weeks ago from Mwave. Just went there.....they aren't selling it.
Well, you can always hit up Ebay. Plenty of ppl there selling new ones.
I'd just buy a Max II if I were you. The OTES cooling prevents you from putting on some of the larger HSF's and the 40mm fan has a high failure rate. I have one and I'm regretting buying it over the Max II... :(
If I were going to get an Abit board for a P4 Northwood right now, I'd get an AI7. I know it's a i865 board, but it doesn't have the problems the IC7 boards have, especially the VTT issue I mentioned.
The Asus P4C800-E Deluxe has all the features the IC7-Max3 had too. I believe the two will overclock the same.
