ABIT IC7-MAX3 with 1.6A. Will it work?
allan_leung
Hello
I went to the abit site and they said it support fsb of 800/533
I check in some review side and they put down 800/533/400 like the one in hardocp.
Does i875 chipset support 400 fsb?
Thanx
Unfortunately, the i875P chipset only supports 533FSB and 800FSB P4s. It will not (officially) support the 400FSB CPUs. For that, you'll need to downgrade to an i865PE-chipset-based motherboard such as the Abit IS7 series.
Originally posted by allan_leung
but on my P4C800-E the website said it support 400 fsb and it's a 875 chipset.
http://usa.asus.com/prog/spec.asp?m=P4C800-E%20Deluxe&langs=09
so does that mean only some company have 875 support 400 fsb?
That 400FSB support for the i875P chipset is 'unofficial', according to Intel. (That is, your system may not boot up reliably with a CPU that has an FSB outside of what the chipset maker officially supports.)
In other words, don't blame Intel (the CPU and chipser maker) if you start having boot troubles or instabilities with that i875P/1.6A combo. And the motherboard maker will tell you to 'use that combo at your own risk', as well - they will not give technical support for an officially unsupported combo.
others have posted success with running 400mhz fsb cpu in 875 chipsets
No matter what they say, it will work. Besides, that 1.6A will be running a 533+ FSB anyways, am i right?
