Abit IC7 Max3 & Processor Utilization
Fr33lancR
I do believe that I have a bad board. Processor usage on the "Performance" tab of task manager is showing 50%, always, but under the "Processes" tab of task manager there is 99% system idle. I have a 2.8c that was running just fine on an Intel 865PERLL. I picked up the Abit IC7 Max3 to do some OC'ing. I switched the boards and all went well. I was rendering some video in Premiere Pro and thought I'd check out the proc. util. All looked ok until I closed Premiere. Thats when I noticed the utilization was sitting at 50%. I needed to reinstall the OS anyway, so I did. before doing anything after the clean install of XP Pro SP1 I booted up to find the same problem. So I did the bios thing. No go. I switched Procs to a 2.4 533. Same thing. I switch HSF. Same thing. If anyone has seen such a thing, enlighten me please. I think I need to get a new board. Any suggestions would be great.
Have you checked your memory for errors? I had a similar problem that ended up being a virus... but that was one of the steps I took to eliminate possible problems. So try that one out.
Use MemTest
It could be a bad board. But there are alot of other diagnostics to do first before ruling that is the case.
Just put everything back onto the Intel 865PERLL. All is good. It's gotta be the board.
