Abit IC7 Max3 - IDE cntrllr problems.
dwayne001
OK, so I just installed XP onto my new 250gb sata drive on what the mobo calls IDE channel 3. I have the ide set-up on the board in enhanced mode, which should, according to it, allow for six drives over the 4 ide channels (for simplicity let's call them ch. 1-4)
So IDE channel 1 has no drives connected to it during the install and IDE channel 2 has two optical drives on it during the install. IDE channel 3 is where my new C drive is placed, it's a SATA conection, so the whole channel is one drive. IDE channel 4 is empty.
I get windows xp pro on it (on the drive on IDE channel 3) and then shut the machine down and plug in another sata drive into IDE channel 4. It starts up, I see the drive, no problem
I turn it off, and plug in the drives I want to use on IDE channel 1. I turn it on, and I get a Boot Erro, no system disk. Insert System Disk and press ENTER.
It seems to me that once IDE channel 1 is connected to drives, the mobo's looking for windows on that thing, rather than looking, seeing that no OS is present, and moving on to channels 2, 3, and 4, where it would find an OS on channel 3.
How come it's not doing that? If I take the drives I have on ide 1 offline, or disable the controller it works fine. When I had RAID 0 running off of what's now called IDE channels 3 and 4, I had no issues with IDE1 being enabled and getting acces to the drives (or a solid bot for that matter).
Any suggestions as to what's going on?
I have IDe bus master off and I think i'm using bios revision 1.4
When ever there is a drive present in IDE1 it will want to boot to that drive.
You have to change the hard drive boot priority.
There is an option that will probably be called hard disk boot priority.
It uses this to know which IDE drive to boot from, find it and change it to the sata drive.
Also turn IDE bus mastering back on.
Indeed, just change the boot order. It is in the BIOS. You could set it to boot off of IDE 6 or IDE 2 or IDE 1 or whatever. Right now it is set to boot off of IDE 1 before IDE 3, and because there is a drive in IDE 1 it fails, before when you had no drive on IDE 1 it did not matter.
==>Lazn
OK, I'll try that tonight when I get home.
Why they couldnt set the damn thing to look for an OS on drive after drive until it found one I don't know.
Thanks again, will check in tonight to let you know what happens.
You can set it to do that, in the same place where you set the boot order (up to 4 devices) there is an option for "try other boot devices" and if that in enabled it will keep trying everything it can do to boot. (but it slows down the boot process)
==>Lazn
The machine is up and running and IDE busmaster is enabled.
Thanks guys. Once i got XP SP2 in there things went smooth as pie.
ya, this screwed me on my first install with this system. pain in the but.
