ABiT IC7-MAX3 bios problem
STrAYeR
Ok I have a IC7 MAX 3 Mobo, and i updated the bios for it, and everything was fine, but after it restarted it wouldnt start. Just a blank screen. the system was on, just dead though. either bios 16 or 17, but it was 2004 bios update. I tried switching cpu's, cause that worked before, when i did a update. But this last time it didnt work. So is the board just dead and i was a unlucky or is there something I'm doing wrong I can fix it.
Current board i have now is a asus p4c800 deluxe, but I really liked the IC7-max3, so if i can get that back up and running, Im going to build another computer.
I have a ic7g and it has a indicator light that lets me know the board is getting power. But that aside, I had a similar problem, and it was caused by the a USB hub. For some reason whenever the hub was connected the board would not boot, as soon as I disconnected the hub the board would boot up perfectly. Some conflict I guess. I heard the same thing happening with USB readers or flash drives connected.
Believe it or not I've actually seen this happen with stupider things. At a LAN recently one guy couldn't get his computer to boot....it turned out that it wasn't booting when he had his microphone plugged into his soundcard....unplug it and it worked. :p
Never underestimate the horrid complexity of a modern PC. ;)
