ABIT IC7 MAX3 Beeping?
Vermicious Knid
I just got a abit ic7 max3 as part of my recent upgrade from an asus p4t533-c, when playing games(i play mostly CS and UT2k4) the board will sometimes beep at random moments. It gives out a single chirp and then will be quiet for 30min or so and do it again, my old board never made any noises, except at boot up, is this normal for Abit boards?
Hmmz, I just built a computer with that exact board, and no problems, but it is for medical and research programs. I have another computer I built for a friend with an IS7, and we found out that the beeps are from the settings in the bios telling you that the board or proc is getting too hot
Are you running Hardware Monitor or some other temperature program in the background?
When I run hardware monitor in the background while gaming it will beep periodically to let me know the temp threshold has been reached.
that sounds like a heat issue to me...something on your board is getting hot...either the CPU, Case temp or the power circuits...
i would check those things out...prime95 the machine for a few hours and see what gets hot and if you experience the beeps running p95.
yea it sounds like a heat issue, not sure if the CPU or the mobo is getting enough cooling/air flow.
I've seen that happen with Asus boards ... usually, it means that one of the voltage rails is falling below its respective tolerance.
Some boards will beep if you're pressing too many keys on the keyboard, happens sometimes playing games... That may be the issue, I'm trying to remember if my IC7 has ever done that.
Check your motherboard manual to see which hardware monitoring chip you have on your mobo. Since its an ABIT, its most likely a Winbond chip.
The beeping you occasionally experience in games is most probably due to one of the voltage rails falling below its respective tolerance, especially if you have:
1- A newer VGA card like the 9800Pro which has a power connector.
2- A weak power supply that cannot deliver ENOUGH CONSTANT power under load.
Solution:
1- Check your voltage rails.....get a better PS
2- Check your temperatures.
