I just bought a new Abit AX8 motherboard with two Hitachi 160GB hard drives. I hit tab after the bios screen and I set up the RAID 0 array. Then I hit F6 during the windows setup when it says "do you want to install a 3rd party raid drivers". I hit S and then install the via raid driver from the floppy. I then hit enter and windows continues loading. Then it stops and says that the file "viaraid.sys" file could not be found and aborts the install. This is the same file that it says that it loaded earlier on. Can any of you help me with setting up this raid array? Am I doing something wrong or forgetting something? Thanks.
