Alright, I've been using this one setup for about six months, and I've been dealing with unstableness and crashing about every few hours I play games.
My Current setup:
RAIDMAX X1 ATX Case
Antec TRUEPOWERII TPII-480 BLUE ATX12V
ABIT AX8 Socket 939 VIA K8T890 ATX AMD Motherboard
AMD Athlon 64 3500+ Venice 1GHz FSB Socket 939 Processor
SAPPHIRE 100600L-Red Radeon X800PRO 256MB GDDR3 PCI-E x16 Video Card
2x CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200)
2x Western Digital Caviar SE WD3000JD 300GB 7200 RPM SATA150 Hard Drive
2x NEC Black IDE DVD Burner
Polyview PT-518A Silver-Black 15" 16ms LCD Monitor
Compaq 15'' CRT Monitor
Everything is running stock, no OCs whatsoever.
Only now do I have the money to deal with any hardware part problems, so I'm looking for suggestions on what to get (and any other suggestions to what may be the problem. I've been told on the Sapphire Forums that:
I've tried updating the drivers to the most recent ones, but no dice. Anyone know if this is true and if I should switch to a different mobo? If it is true, any suggestions as to what I should get? Price isn't much of an issue, though cheaper would be better for me.
My Current setup:
RAIDMAX X1 ATX Case
it's probably the chipset on the board not liking the 90nm vencie core (seeing at the kt890's were the first 939 pcix boards released and via has since ceased production of them) I'd say try updating the bios and chupset drivers if the problem still persists we'll have to try something else.
