ABIT AW9D-MAX Problem - Doesn't recognize CD drive - HELP!
BlackHawk22
The title says it all, it doesn't seem to know what a CD/DVD drive is. It has power, and the tray works, so IDK. Anybody here have the same issue?
is it a SATA drive or ata?
also does the drive work in another PC?
can you hook it up to another PC and update the firmware on the drive and then try it in your mobo....
thats all the general help i can give... post what drive and PC specs...
Its not the drives issue. And if you read the headline or even my post - it is a CD/DVD drive, not a hard drive. It worked one hour before. This is a mobo issue.
They do make SATA cd-drives :rolleyes: . You seem to have a bit of an attitude issue here. Calm down man, we understand that this shit can get frustrating, but we are only here to help ;)
So..did you do what Adidas4275 said..move the drive to another computer and update the bios..let us know what happens
The CD drive could of gone bad. Also did you check the connections? Maybe the cable was barely making contact with the CD drive and you tapped the case and it came lose. It has happened to me before. Also, like previous posters has said, try testing it in another PC to verify it is indeed a mobo problem.
